DIY - Lipo Voltage Monitor (In Flight)
    Tip
    Oh, that a easy potential meter to build...thanks for the tip.
    By the way, I realise that the battery voltage falls very quickly once it hit 9.5v with the heli at hovering. So infact if the LED only lights up at 9.4V, the battery will be out in matter of seconds. May have to change the resistor value to light up the LED at slightly higher voltage than the 9.4v. Maybe 10V?
    Any advise?
    U can use 2 or more resistor in series... and then the o/p is tap between that series of resistor to give u voltage divider.... therefore, can create a very very very simple variable voltage supply.
    U can use potential/variable resistor to do the job as well.
    SH
    Heli
    Honey Bee CP2 : Sold (Maiden:17 Dec 05)
    Trex 450XL (CDE) : MM450TH, Quark 33A, GY401, JR RS10DS (Maiden : Align Frame - 1 Jul 06; SuperFrame - 29 Aug 06)
    Plane
    Estarter : Align 450s, Align 25A, Electron 6 (Maiden :16 Sep 06)
    PT-17w : Sold
    Buggy
    Acme NB 16 : Half 8 Nitro (Maiden :23 Dec 06)
    Transmtter : JR PCM 9X II, Aggressor SRX
    Charger : Tahmazo T15
    Balancer : TP205
    Battery :Thunder Power, FullRiver, Warbird
      UPDATE : Lipo Low voltage warning
      This is just an update:
      I have found a suitable casing for my Lipo voltage Indicator. It is actually the cover of a blade storage box. Fits perfectly, just need to seal the back. Soldered the 2 wires directly to the battery connector.
      The LED works fine and lights up bright when the LIPO voltage drops below 9.5v during flight.
      Please refer to the attached photo....
      Heli
      Plane
      PT-17w : Sold
      Buggy
      Balancer : TP205
        hi bro,
        i think this is the update for your circuit diagram as the one you are having have problems when operating at high current.
        latest diagram
          Hi Nizam,
          Thanks alot....didn't realise there was a revised version. Will see if there are big differences....
          When will you be coming for FF again?
          See ya!
          Originally posted by nizamysf
          hi bro,
          latest diagram
          Heli
          Plane
          PT-17w : Sold
          Buggy
          Balancer : TP205
            help needed.............
            i have just done up the volt meter
            but the LED lighted up even in 4.8v,9v and 11.1v
            it seems that the meter is not working
            btw i try turning the 1k trim
            but at all volt,,, the LED lighted up
              Hi zattan22,
              This is a rather easy DIY and it should work if you have followed all the values and wiring correctly. I suggest you carefully recheck your circuit.
              As for me, I did not use the design with the trimmer. Till now it works perfectly.
              Heli
              Plane
              PT-17w : Sold
              Buggy
              Balancer : TP205
                just got the volt meter to re-check the V in adn out of the trimmer
                  is urs version 1 or 2????
                  i tried version 2 but the readings before and after the trimmer is 7.7v and 0.29v
                  how to get 7v plus and 9v plus as stated in the diagram
                  if no one can help,,
                  ii have to convert to the version one without trimmer liao
                    Hi zattan22,
                    I did the simple version 1 without the variable resistor. However, if you do that, you need to ensure that the tolerance of the resistors are very small, else the triggle voltage will not be accurate.
                    I am not sure what you mean by "the readings before and after the trimmer"??
                    Based on what I understand, 'detection voltage' is the operating voltage range of the circuit while adjusting the trimmer port from min to max. In other words, if you set the port to min position, its 'detection voltage is 7.7v and with the trimmer at max position, the 'detection voltage is 9.8v. (ie for 3s)
                    It is not meant to tell you the voltage level before and after the trimmer point.
                    What I did is to use a few 9 volt batteries with different voltages to test out the functionality of the circuit. If you have a variable DC Power supply, you can input it to the circult and trim the circuit (VR1) till the LED lights up at your prefered voltage level. Based on you 3s circuitry, the range it operate is 7.7v to 9.8v.
                    and....be happy, this is a hobby
                    Hope this HelPs
                    Heli
                    Plane
                    PT-17w : Sold
                    Buggy
                    Balancer : TP205
                      huh..............
                      btw the volt meter connect to
                      the receiver by using y-cable???
                      or
                      connect to the batt and the esc???
                        I would call it Voltage monitor iso voltmeter to avoid confussion.
                        You connect the Lipo Voltage Monitor to the battery connector in parallel. Just use a small wire to tap to the battery connector directly (not the battery!)
                        hOpE thIs HelPs
                        huh..............
                        or
                        Heli
                        Plane
                        PT-17w : Sold
                        Buggy
                        Balancer : TP205
                          huh..............
                          or
                          The receiver point => ~5V only...
                            i have done up the voltage meter
                            but can not find the 3.6M ohms resistor
                            may i know where to but them???
                            currently, im using 3.9M ohms resistor for R1
                            but the LED only flackle dimmly.......
                            Pls help.............thanks
                              Hi zattan22,
                              Did you follow the circuit closely?
                              From what I see, R1 should be 1k ohm not 3.9M ohm and R3 should be 560 ohm resistors.
                              If you are using 2s battery, then you select 820 ohm for R2
                              If you are using 3s battery, then you select 2.2k ohm for R2
                              If you are using 4s battery, then you select 3.9k ohm for R2
                              You are using the wrong value for R1. Also, you need select the correct type of LED - Ultra Red LED as different LED has slightly different operating voltage.
                              You can get any kind of value the resistors at Sim Lim Tower. Many shop at basement also sells them.
                              hOpE ThiS HelPs
                              Heli
                              Plane
                              PT-17w : Sold
                              Buggy
                              Balancer : TP205
                                sorry....
                                for the misunderstanding.
                                im doing the 1st version of volt meter....
                                it only have 2 resistor...
                                for the version 2,
                                i have give up liao
                                the version 1
                                has only 2 resistor
                                1st R1 is 3.6M ohms and R2 is 510K ohms
                                but i can only manage to get R1 3.9M ohms
