That's nice.... Where did u get the voltmeter? Did u do it urself?
PC Power Supply for DC Charger?
Originally posted by awesomesaw that you selling psu..how much will you charge for a psu like this??
For the price I will PM you.EPP WARBIRD P51
HS55
Optic6
Originally posted by simonwooGuys, will I be able to use this IBM notebook adaptor for my IMAX B5? Thanks!For some people it's important to show what they have, for others it's sufficient to know that they have it.
hi guys, need some help here on psu.
Just gotten 1 PC PSU from another seller. Comes with all the wirings, typical of a pc psu. Oso gotten an orion advantage charger whch requires a DC 12V input. Tested the psu the moment i rch hme n it is working fine. Seeing all the 'junk' wires whch i do not require, being the ignorant me, happily cut off the extras, leaving oni 1 black n 1 yellow whch churns out 12V 18A. Then, tested the psu, NOT WORKING!!! After closer inspection of the cut wires, i notice teres a big chunk of wires whch are bundled together with the black n green wire shorted. Then i tried to short the only green to all the black(1 by 1) but still to no avail. However, in the process of trial n error, the psu fan did move a little everytime i power on, but cannot boot up. Im dead sure nothing was shorted in the process. if my electronics memory did not fail me, all the black wires shld oni be ground whch esentially will not make any diff regardless of whch one i connect to the green. Wat cld be the potential prob?
will post some pics when i get hme. thanks.
suspect you need a "load" for your psu.
try shorting the green wire to any black wire again.
do not use hand to hold it, solder and shrink tube is the best.
connect to your charger, or any "load/resistor" then power up again.
it should work. (try using a old 12v fan if uncomfortable using charger)
for safety reason,
bundle the same colour together then use same isolation tape
to cover the naked wires since they are expose outside the case.
XRB SR Lama
Robotis Bioloid
Robot Bear
for safety reason,
Originally posted by BenziTdid you cut the "unwanted" wires all at once ?
if so, you might have " sorted " the PSU. as there are still residual charge in the electronic parts.
If so.. really RIP liao
If not.. i no idea liao
However, like wat i mentioned prev, everytime i tried to power on after the trial n error between the green n black wires, the psu fan & light will kickstart a little but never fully power up........
