Losi Mini High Roller 1/18th Scale Truck
    For Sale is a Losi Mini high roller that was purchased in 2011, i have added some hop-ups like aluminium spur gear, aluminium slipper, titanium turnbuckles aluminium front and rear pivots, threaded aluminium front and rear shocks.
    I had upgraded the stock motor to a 7700kv brushless leopard hobby and a trackstar 18amp brushless ESC, however the ESC had failed on me, i dont know what happened it just stopped working, so i switched back to the stock ESC and Brushed motor, i will give the new owner the leopard brushless motor that's brand new about a week old and also a trackstar 4400kv brushless thats brand new but the mounting holes are different and modification needs to be made on the motor mount if you wish to use this motor and the broken ESC as you might be able to fix it if you know how (my advise is to buy another one from hobbyking.com or asiatees.com).
    The current stock ESC can run 2s lipos but i still choose to run the stock NIMH batt on a brushed setup.
    i have changed the batt and ESC to Deans plugs and you will need your own charger to charge the batt as the supplied one is USA rated 110v
    what you see in the pictures is what you will get. the total value of the items below is around 400 SGD im asking for 300 SGD slightly negotiable.
    The car runs great and even the stock setup is fast, i have not bashed this car up only played around my car park, Truck is RTR with Losi stock Spektrum 2.4 TX & RX
    Deal will be done at Tampines St 45,
    SMS or Whats app 93688477 Don
ID:	994141Click image for larger version
ID:	994140Click image for larger version
ID:	994139Click image for larger version
ID:	994138Click image for larger version
ID:	994124Click image for larger version
ID:	994127Click image for larger version
ID:	994126Click image for larger version
ID:	994125Click image for larger version
ID:	994128Click image for larger version
ID:	994137Click image for larger version
ID:	994136Click image for larger version
ID:	994135Click image for larger version
ID:	994134Click image for larger version
ID:	994133Click image for larger version
ID:	994132Click image for larger version
ID:	994131Click image for larger version
ID:	994130Click image for larger version
ID:	994129Click image for larger version
