RTF Quad with battery, ARF Innova BD 450 with alot of spares and Battery, Turngy 9x + Receiver ,
    Dear Gentlemans,
    Clearing my stores and have the following to let go due to various reason.
    CF Quad with kk controllers + programmer, Motors + Esc & Batteries ( 3 x 2200 mah zippy 20c + 3 x old 2200 mah 35 c) + Turnigy ER9x + 2 new 8 CH receivers - for $380
    ( you will need a 3s capable charger and props saver (rubber rings as my is broken - i think gfk sell 1 bag of 50 for 5 dollars)
    *My brother give up for the above due to work commitment thus store for quite sometime.
    6s - Innova BD 450 - with YGE 60a , Scorpion 2221-2010kv , Cyclic - Savox 257 , Tail - Futaba 9257 , 4 turnigy 1300 mah 6s batteries , previous 3 x metal gear kds cyclic
    plus many many spares like 3 x boom ,4 x feather shaft,6 pair x new blades, main gear + new unused canopy . etc etc . - $520 ( only thing you need is gyro which you can grab like robird G31? and receiver , tx and charger? )
    Other than the above upgrades, there is unbreakable skid , and tarot dfc head with tarot swash plate.
    I'm always flying my protos - seldom fly innova now
    If you keen you may whatapps me on 97866864 or pm me
    Not in a rush .. so you can take your time to think.. i might not reply very fast
Name:	New Canopy.jpg
Name:	Turngy 9x , flashed to er 9x with LiFe battery.jpg
Name:	Feather Shaft, Main Shaft, Main gear, tail shaft  , etc.jpg
Name:	Scorpion 2221-2010KV.jpg
Name:	Blade , link , belt , battery , main shaft collar.jpg
Name:	Quad Battery and receiver holding.jpg
Name:	Futaba Tail Servo 9257.jpg
Name:	Servo Links , Belt, Battery.jpg
Name:	Receivers, new zippy 20c 2200 mah,kk programmer.jpg
Name:	Innova 450 BD.jpg
Name:	Tarot DFC head with Tarot Swash plate.jpg
Name:	CF frame quad with 4 motor and 4 esc and kk controller.jpg
Name:	Savox Cyclics 257.jpg
Name:	6 Pair Blades.jpg
    J.S Carlos
    Hanger
    • Goblin 500
    • Copter X SE 480 - 3s HeliDrive 3600KV - Robird FBL
    • MSH Protos 500 Low Hub Stretched - Brain FBL
    • Spirex - TriCopter - Pcs of Crap Hanging on the Wall
    Tx
    • 8fgs
    • Devo7
    • Devo7e
    All PM reply.
    Not selling separately. wish to make it good deal and clear together
    yes, Innova is using shorter main shaft and hub for better rolling.
    yes, KDS MG Cyclic is N300 , use about 8 flight before upgrade.
    Battery , about 20 cycle
    Quad's kk board does not support this so call GPS position, wind blow still will drift.
    Originally posted by Tearsnitez View Post
    Dear Gentlemans,
    [ATTACH=CONFIG]119902[/ATTACH]
    [ATTACH=CONFIG]119909[/ATTACH]
    [ATTACH=CONFIG]119899[/ATTACH]
    [ATTACH=CONFIG]119906[/ATTACH]
    [ATTACH=CONFIG]119896[/ATTACH]
    [ATTACH=CONFIG]119903[/ATTACH]
    [ATTACH=CONFIG]119910[/ATTACH]
    [ATTACH=CONFIG]119900[/ATTACH]
    [ATTACH=CONFIG]119907[/ATTACH]
    [ATTACH=CONFIG]119897[/ATTACH]
    [ATTACH=CONFIG]119904[/ATTACH]
    [ATTACH=CONFIG]119901[/ATTACH]
    [ATTACH=CONFIG]119908[/ATTACH]
    [ATTACH=CONFIG]119898[/ATTACH]
    [ATTACH=CONFIG]119905[/ATTACH]
    [ATTACH=CONFIG]119895[/ATTACH]
    J.S Carlos
    Hanger
    • Goblin 500
    Tx
    • 8fgs
    • Devo7
    • Devo7e
      Up for nego.
      J.S Carlos
      Hanger
      • Goblin 500
      Tx
      • 8fgs
      • Devo7
      • Devo7e
