For a more detailed review, check this one out!
July 15th Update
Found out why my Tricopter is behaving so strangely, apparently the silicon gel padding I placed below my tail motor made things worse, I have since removed it leveled it to the servo using hard wood strips. Also I found the best settings from rcgroups for the KK2board PID settings and here they are. Flies super stable right now!
gyro aileron\elevator
p gain 35
p limit 100
i gain 25
i limit 20
gyro rudder
p gain 45
p limit 100
i gain 20
i limit 20
self lev
p gain 65
p limit 65
i gain 0
i limit 0
The Settings below are Obsolete! Do NOT use them!!
Important update! Just came back from a test flight and discovered a few things.
The settings below are not good for forward flight!!! It is only good for hovering. The P settings have to be reduced further to the 60-80 range for a good forward flight, using the settings below will result in it rolling periodically during forward flight. Seems that I will have to do more tuning to get it to fly reasonably. Good thing is that the auto level works very well and will provide a very stable platform for aerial videos.
2nd Update
New Settings - This setting is the most promising so far
Roll/Pitch
P Gain - 45
P Limit - 100
I Gain - 60
I Limit -20
Yaw
P Gain - 65
P Limit - 20
I Gain - 50
I Limit -10
3rd Update
I have just returned from flying and the above settings are NOT good for flying in strong winds. The values are still too high
This is the latest values I have, it is a little "Drifty" but at least it doesn't give you surprises and can handle very strong winds. Now it is just up to the skill of the pilot.
Roll/Pitch (Aileron/Elevator)
P Gain : 30
P Limit : 100
I Gain : 3
I Limit : 20
Yaw (Rudder)
P Gain : 30
P Limit : 20
I Gain : 3
I Limit : 10
Stick Scaling
Roll & Pitch : 50
Yaw (Rudder) :70
Throttle : 100
Onboard Flight video. Testing the response in the first half and on 03:35 onward I go crazy with the controls.
Before I start with the review I'll post the settings I have for my Tricopter. I have a clockwise prop (rev) for the left boom and counter clock wise props for both the right boom and tail boom.
Lets go through the PI gain settings
I got these settings after much trial and error and going through 3 battery packs. Resulting hover characteristics is stable and feels more locked on than the older KKboard, though I must admit that the older KKboard is easier to setup.
Miscellaneaous, Auto Level and individual Channel Mixer Edit settings
Will continue in the next post as there's a image post limit.
July 15th Update
p gain 35
p limit 100
i gain 25
i limit 20
gyro rudder
p gain 45
p limit 100
i gain 20
i limit 20
self lev
p gain 65
p limit 65
i gain 0
i limit 0
2nd Update
Roll/Pitch
P Gain - 45
P Limit - 100
I Gain - 60
I Limit -20
Yaw
P Gain - 65
P Limit - 20
I Gain - 50
I Limit -10
3rd Update
P Gain : 30
P Limit : 100
I Gain : 3
I Limit : 20
Yaw (Rudder)
P Gain : 30
P Limit : 20
I Gain : 3
I Limit : 10
Stick Scaling
Roll & Pitch : 50
Yaw (Rudder) :70
Throttle : 100
