Show bottom must pay money
Glider for Intermediate Pilots - Vladimir Models Mini Graphite
Originally posted by Hawkeye View PostShow bottom must pay money
Ps: I should charge also for the new design for my Backfire , only one other person know so must share share ....:-)
Originally posted by JYHELI View PostAiyo we are all old generation already including me, now a days young people show for free on Facebook....:-)
Ps: I should charge also for the new design for my Backfire , only one other person know so must share share ....:-)Beastx installed and flying ...
[SIGPIC][/SIGPIC]
Bottom is simple dark blue with white stripes...
What ever the design, top and bottom must look different to differentiate orientation of plane. Bottom always dark, top always bright. Extremities(wingtips, tail and nose) must have good contrast against the blue and grey skies we have here.
Not good enough to look chio....must be practical too. So far Neon colors are the best. But depends on who does the paintjob as Neon colors fade fast with too much sun.
As for power setups, still considering. I want it to be a hot dogger aerobat. Not so much for speed. The plane not designed for it.Do you feel the RUSH....!!!!
I started the build by setting up all the wiring harnesses to the servos. I planned to make the tail removable so I used deans 4 pin as the main interface.
Like wise for the wing halfs, each side got a 6mm hole drilled 130mm back from the leading edge and 10mm inboard. Wires threaded and terminated with deans 4 pin.
Last nite I started on the flap servo installation. I'm using MkS mini with the frames. The plywood frames are soaked with CA to toughen and stiffen the frames. Than everything is dry fit and also to determine the length of the pushrods and the position of the servos. The clevises are loctite to the rods to ensure no slop. The sub spar had to be grounded down to make sure the push rods did not get interfered with throughout the full motion of the servos.
