Jet Legend F15 Turbine
    Posting on behalf of friend.....
    For sale a brand new never flown Jet Legend F15 turbine jet. 80% built
    Scale: 1/10
    Wingspan: 55"/1400mm
    Length: 80"/2050mm
    Weight: 19Lb
    Turbine: 6-12Kg
    Jet is newly built with Hitec Titanium servos throughout. Comes with a brand new i-jet Black Mamba turbine
    Max. Thrust: 14.0 Kg (30.85 lb) @126,000
    Residual (min) thrust @ idle: 0.45 Kg (1.0 lb)
    Max sustainable shaft speed: 126,000 RPM
    Idle Shaft Speed: 33,000 RPM
    Max EGT: 580°C - 650°C
    Response: 0-100%= 2.5sec; 50-100% = less then 0.5sec.
    Fuel: Kerosene, Jet A1
    Oil: full synthetic 2-Stroke Oil; Aero Shell 500
    Fuel - Oil Mix Ratio: max. 4% oil added to fuel volume
    Fuel Consumption: 330g/min. @ full power
    ECU: FADEC V10 (Type AU-107K), c/w Handheld Data Terminal (HDT) *1)
    Dimensions: 115 Ø x 320mm overall
    Weight (turbine/E-start/straps): 1.55 Kg
    Interested party please text me at 9644-6681
    Moved to "For Sale" thread. Apologies for the wrong thread posted
