Selling SBACH342 55in designed by Hokusei RC and Dualsky XM4250EA-8
    Selling SBACH342 55in designed by Hokusei RC.
    Plane only (no motor, ECS or servos) at $150 neg.
    Also selling Dualsky XM4250EA-8 560KV. For use with this plane with 2x 3S2200mAh battery. Price for motor is $50.
    Buy both item at $180 neg.
    Selling because got new project. Plane is in good condition. This is a 3D plane that can do all the 3D stuff, harriers rock steady, elevator is effortless, hovers well, knifeedge is incredible, goes into knifeedge spin so easily, etc. Got to improve my skill to realise it's full possible. Just check out youtube videos & you will see what it can do.
    Please note that the under-carriage had been broken and glued back using fibre-glass cloth and epoxy/CA.
    You will need 4 Hitec HS225MG and a 60A ESC and the above motor and 14x7 prop.
    Spec from web-site:
    Wingspan: 1,400mm (55in)
    Length: 1,350mm (53in)
    Weight (w/o battery) : 1,815g and with battery 2,195g
    Recommended motor: Dualsky XM4250CA-6 KV840 (for 4S3300mAh) or Dualsky XM4250CA-10 KV510 (for 6S2200mAh)
    ESC: Dualsky XC6018BA-V2 60A  or HobbyWing  PLATINUM-60A-PRO
    Battery:4S 35C 14.8V 3,300mAH
    Propeller: HS 14x7E
    Check out the spec and video at:
    Call/sms me at 98006159. Deal or view at Pasir Ris or Tampines SCDF field.
    Thanks for viewing.
    More pics
    More pics
      Bump
      Bump
        Bump again
        Bump again
          Bump Again 1
          Bump Again 1
            Still Available
            Still Available
              up
              Originally posted by joeykwek6432008 View Post
              Still Available
              up
                Plane sold, motor still available
