Originally posted by Sebastian It will work if you're juz hovering or normal FF, cant do loops with this blades if you dont have extended booms. it will hit the tail blades.
Actually it won't hit the tail blades at all if u do the correct phasing..
Phasing means when u rotate the blades manually,
when the main rotor is at the tail, the tail rotor shld be horizontal with the tail boom..
This way, there is no way of the tail blades hitting the main rotor at all..
