Up for sale is this brand new Freewing model AL37 in Singapore Airlines livery.
Customized decals from Callie Graphics
The front and rear landing gears are made of aluminum alloy and have shock absorption function and will make scale landings on the mains an enjoyable experience with each and every flight. Also, the larger size of the wheels (Nose wheel diameter: 45mm, Main wheel diameter: 70mm) make take-offs and landings a breeze in most grassland environments. This model has a beautiful air posture, and good stability in high and low speed.
The model is brand new and has not been flow, all checks are done as per video.
No rx, lipos are included.
PM me for viewing and price.
Model Scale | 1/19 Scale |
Wingspan | 1830mm / 72.04in |
Length | 2000mm /78.74in |
Weight | 3350g / 118.16oz |
CG (Center of Gravity) | 185mm from the leading edge of the wing root |
Power System | 2x 6S 3048-2150kV Outrunner Motors (included) |
Electronic Speed Control | 2x 60A with 8A UBEC (included) |
Propeller / EDF | 2x 70mm 12-Blade EDF (included) |
Servos | 6x 9g Digital Metal Gear Standard Servos 4x 9g Hybrid Digital Metal Gear Standard Servos |
Landing Gear | Electronic retractable (included) |
Required Battery | 6S 22.2V 4000-6000mAh LiPo with EC5 Connector (required) |
Required Radio | 6+ Channel (required) |
