Release a quality Balsa High Wing Hangar 9 Ultra Stick 60” Wingspan PNP in pristine condition as only fly on the maiden day @ S$668. More info on the ARF version is available @ https://www.horizonhobby.com/product...0/HAN2345.html
The plane is setup with the following brand new and quality components for 6S Electric Power, 6 Servos (2 for Ailerons, 2 for Flaps, 1 for Elevator, 1 for Rudder)
1. Extreme Flights - Outrunner Brushless Motor
2. Extreme Flights - The AirBoss 80 is a 3D-ready 80 amp ESC For 3D aircraft 55-65" wingspan, with 4S-6S lipo packs. Weight: 85g
3. Futaba Digital Servo S3072HV S.Bus Programmable High Torque Digital High Voltage Servo. This single ball bearing servo is ideal for airplanes, cars and boats. Futaba S.Bus High Voltage Servos are capable of using up to 2S LiPo's to maximize speed and torque. S.Bus compatibility adds the best in setup simplicity, while programmability provides the ultimate in performance tuning.
Specifications:
Attached are photos of the Plane. Feel free to contact me at Nine430899Three if you are interested. Collection in Sengkang (weekday daytime or nighttime) or at OHR (on Sat. or Sun. morning).
http://
Hangar Ultra Stick 60” - Photo 1 by hctay, on Flickr
Hangar Ultra Stick 60” - Photo 2 by hctay, on Flickr
Hangar Ultra Stick 60” - Photo 3 by hctay, on Flickr
Thanks for viewing
4016T-500 MKII | 16/500 | 292 gr | 80 amp burst (20 sec) | 6mm | 5S/6S 14x7-16x7 "E" Prop | The Torque Revolution 4016-T500 brushless outrunner is a 5S/6S powerhouse! Capable of 80A burst current while maintaining very acceptable temperature, the Torque Revolution will revolutionize .40-.60 sized electric aircraft conversions. Recommended Props: 15x8, 16x7, "E" Prop |
Specifications:
- Torque:
- @6.6V: 80.6 oz-in (5.8 kg/cm)
- @7.4V: 90 oz-in (6.5 kg/cm)
- Speed:
- @6.6V: 0.17 sec/60°
- @7.4V: 0.15 sec/60°
- Size: 1.57x0.79x1.50 in (40x20x38.1mm)
- Weight: 1.5 oz (42g)
- Power Supply: 6.0 - 7.4V DC
- Bearings: Single
http://
Thanks for viewing
