Offloading 6 month old DJI F550. What's included:
1. F550 Frame x 1
2. DJI E300 Motors x 6pcs
3. DJI E300 ESC x 6pcs
4. Phantom 2/Vision E300 Self-Tightening Rotor Props-Gray x 6 pcs
5. BNIB (Seal in box) Naza System M Lite + GPS x 1
6. Futaba T8J 2.4 R2008SB Receiver x 1
7. Landing Gear Upgrade Set x 1
8. Helipal Camera Positioning Kit (660mm) x 1
Everything is wired and calibrated before with a Naza V2. You will need to rebind them and calibrate with the M Lite. If you are only familiar with V2 Naza Assistant program/layout or UI then just flash the M Lite to V2 4.0.2. This will allow the Naza Assistant to recognize the Naza Flight Controller as a V2 and not a Lite. This will also give you better stability and satellite locks.
What you will need:
1. Futaba transmitter or any other tx/rx combo of your choice. I highly recommend Futaba T8J.
2. Lipo battery and lipo balance charger.
Looking for at least $650 all in. Not open to negotiation or trades.
RFS: Moving to foldable frame.
1. F550 Frame x 1
What you will need:
