Hi guys. I'm selling a beautifully built, tunes and test flown quad.
This is the Ecks frame, from Sweden. http://www.ecksstore.se/#!frames/cs0c
These are the components used in the build,
Ecks frame
Keda 2730 motors (1500kv, super lightweight motors for longer flights and efficiency)
12A ESCs (SimonK flashed)
KK2.1.5 FC (great for beginners and experts alike, can change settings at the field with the 0n-board LCD screen, no computer required)
Low voltage buzzer for the KK2.1.5 (no need to use a separate low voltage alarm)
Power distribution board 30.5mm square (great for adding/removing components, small footprint)
8x4.5 props
Special firewall mounts for the motors for a lower profile
3mm collet adapters for the motors
LED strips installed on the front and back to help with orientation
OrangeRx R620 Spektrum/JR DSM2 Compatible Full Range 6Ch 2.4Ghz Receiver w/Failsafe
All cabling and soldering done
Battery strap
Finally, the quad is built, tuned and test flown. Flies beautifully. Great for sport/acro flights and good fro beginners as one-piece wood frame is very tough.
Only flown to test/tune.
Selling for $320.00.
I also have batteries if needed at extra cost.
Whatsapp 97704140
Collect at Pasir Ris MRT.
Ecks frame
8x4.5 props
Battery strap
Whatsapp 97704140
