A beautifully crafted R/C sailboat, fully built and nearly ready to run. All required items are installed, including mainsail winch, steering servo and all rigging, sail and hardware.
All you need to do is add your own receiver and battery! Boat hull is based entirely on an ocean going racing yacht and moulded in fibreglass with a perfect gelcoat and enamel painted finish.
Don't be mistaken in thinking these boats are slow and boaring. In a stiff breeze they can be extremely quick and perform turns rapidly, proving to be very exciting.
This kit comes pre-fabricated and all you need to do is connect the sail and include your own receiver! The large servo winch and steering are already set up and ready to go!
Spec.
Length : 900mm
Height : 1800mm
Weight : 2.5kg
Area of Sails : 0.38m2
Ballast weight: 1.3kg
Draft from the waterline to bottom of keel: 360mm
Rig Height from the deck to the top of the mast: 1330mm
Required. Radio System (2ch) Receiver battery.
The sail boat has only been used for 5 times and look new. It has also never been sail in seawater.
Asking for $100. No low baller please. No PM please as seldom check on inbox. Interested please SMS directly to 96957057.
Thank you in advance.
