Thunder Power TP480 and TP730 Lipoly Packs
Brief Specs
480 mAh, 2 cells (7.4V), JST connector
Rating: 15C (7.2A) continuous, 22C (10.5A) burst
Dimension: 34mm x 50mm x 7mm
Weight: 23 grams
480 mAh, 3 cells (11.1V), JST connector
Dimension: 34mm x 50mm x 10mm
Weight: 34 grams
730 mAh, 2 cells (7.4V), 18G wire
Rating: 13C (9.5A) continuous, 20C(15A) burst
Dimension: 34mm x 50mm x 9.5mm
Weight: 34gm
730 mAh, 3 cells (11.1V), 18G wire
Rating: 13C (9.5A) continuous, 20C (15A) burst
Dimension: 34mm x 50mm x 14mm
Weight: 49gm
Brief Specs
Weight: 23 grams
Weight: 34 grams
Weight: 34gm
Weight: 49gm
