CSM CarbSmart - intelligent engine tuning
Have you ever wondered if your engine is working at it's best or is it struggling?
How about changes in the weather and you're not sure what adjustments would be good for your engine?
Or is it simply blowing pistons because of leans run even when there was plenty of smoke visible during your flights?
As we all know, proper engine tuning in essential to obtaining the best performance and lifespan out of any engine, irregardless of flying skill level. However, the way of feeling for backplate heat is far from the best gauge on engine combustion level.
CarbSmart is used in conjunction with a servo connected to the main needle of the carburettor to adjust the mixture in flight dependant on the cylinder head temperature, which is far more accurate and instantaneous.
Check out some of the reviews by flyers:
