I have an application, a battery-operated handheld power tool, that will use a brushless motor and Lixx battery. (For the sake of concreteness, you can think of the tool under development as a Dremel tool running at 0-5000RPM @ 10 Watt for up to one hour.) I would like to employ one of the readily available ESCs that RCers use, along with batteries and brushless motors. But I will not have the usual Tx/Rx arrangement. Instead, I want the user to select the motor speed with something like a slide potentiometer. Is there an off-the-shelf part I can use for my ESC?
Thanks for your attention!
