I have purchase a KingTech Power EPS with a T-motor T1804 ,ESC Tahmazo Pro-CS-13 13V
Soldered the points together already , plug into the battery 2cell 240MAH (35C)
turn on transmitter, then tried to push the trottle but the motor not turning , is it the soldering problem or...
After a while the battery bloated up some chemical leak i guess the battery is spoiled ,any recommend which battery should i get and what's the problem connected
