I plugged the crystal from the GWS tx into my JR 3810 but the radio just cannot communicate with the DF. If i switch off my Tx, the DF will just spin like a mad bird. isit becoz of different modulation?
dragonfly on JR
Hi
If u using GWS RX, it do not have Fail safe. If it sense no signal, it will just go haywire.
As for the crystal clock, your crystal clock must match the TX. I believe your JR 3810 is a dual mode TX (PCM and PPM). If so, u cannot use single conversion crystal on a dual conversion TX.
Another thing u have to take note is that the crystal clock must in the same frequency range as your TX (That is..example your TX is 40MHz, u have to plug in 40MHz)
Super-Hornet
