Last Sat, while playing boat for abt 2mins already, the boat suddenly stopped operating and I managed to retrieve it. Initially tot it was ESC cut or burnt but instead it was the external BEC stopped working. I tot the BEC gone liao as there was no power to the Rx n my cooling fans.
Pack up n brought it home to check. Using 4 AA cells, I powered up the Rx n ESC without any problem. Dry running the motor was smooth as usual. So main suspect is BEC. Plug in a load to the BEC, LEDs, it powered up w/o problem at all. Tis is funny, I tot its not working. Plugged the BEC to the Rx, it stopped working.
The brand of tis BEC is Hobbywing 3A.
Desolder the BEC from the ESC wires and soldered a brand new Himodel BEC 3A to the ESC. Faced the same problem!!! No power to Rx n Fan when plugged in. The I plugged it directly to the LEDs, they light up. Now I suspect the Rx got problem.
I tried it on another Rx, same problem!!!
Using the 4 AA cell, I got no problem at all. Whatz wrong now???
