Vbar connecting problem
    Good day everyone I have problem trying to connect my vbar to MAC laptop. It prompt me at error message saying "SELECT OF PORT". Can anyone please help me thank.
    No familiar wif Mac, did u have this problem before?
    Too many helis!
      Thank you Prof Liang. I brought this set here from a bro. It is a 2nd hand use set. I follow the online instruction power up my vbar than connect to my MAC than launch the software as per state on the online from mikado. May be I left out some step.
        Maybe u can try wif a windows computer, my vbar never fail to connect to my computer before.
        Too many helis!
          Prof Liang is right.
          In Windows, if there is any such problem, all we need to do is to update the device driver.
          Click the Vbar device in the Device Manager, and then update the driver. The driver is usually in the
          sub-folder "drivers" under the Vbar software installed folder.
          Just need to do it once.
            Thank you nb8686 I'll try to delete my current driver and re-install it. Check will the problem be slove. Still have any suggestion for me to look into solving my connecting issue. Thank you everyone.
              Hi everyone problem still exists after I delete and re-install the driver.
                Use window based comouter ....., vbar dun like mac.
                Too many helis!
                  Thank you Prof Liang. For window I just go to their site and download as per normal what other things do I need to take note of? If I write to Mikado regards this issue will they provide any help for me? Very much thank
                    I am sure Mikado will support u. You can try helifreak, there are more users there than DH.
                    Your disc should be able to install software ver 5.3.4, for usb driver just download from vstabi website, or maybe from ur disc.
                    Too many helis!
                      Encountered same issue. Reinstall driver and that's it. I never owned a mac so cannot help at all. BtwI also use another brand of fbl gyro which works very well with vbar software...
                      Heli-ADDICTION:
                        Thank everyone, I think I should get myself a window laptop.
                          Did it work???
                          Too many helis!
                            Good afternoon Prof Liang Sad to say it don't work but new error message pop out. By the way how to attach photo so I can share it online. To make this thread useful to others if same things happen to them.
                              I use photobucket. Where u stay?
                              Too many helis!
