Hi all, need some help here, i found out that i have stripped one of my motor mounting holes on my 450th ! i cant use the other 2 set of holes because the length between the hole's are different... i was thinking of threading a bigger hole on the existing stripped hole...anyone done this before ?
Motor Mounting Hole stripped
Hi Jonathon,
What frame are you using. If it is the Stock plastic frame, it might be easier to enlarge one of the hole on the chasis (elongate sidewards) so that the holes are set further apart to fit the other pair of good motor screw holes (which I think is further apart than the strip one).
Otherwise, you will have to tap new thread but be careful not to drop any metal parts into the motor during tapping.
hOpE thIs HeLPsHeli
Plane
PT-17w : Sold
Buggy
Charger : Tahmazo T15
Balancer : TP205
