HPI Hellfire
    HPI Hellfire
    New from HPI! Buay tahan sia...
    Coming soon from HPI Racing is the Hellfire, a purpose built, Ready-to-Run high performance, 1/8 scale four wheel drive monster truck. The Hellfire offers maximum performance in all conditions by combining the durability characteristics of the Savage with the agility of 1/8 scale buggies. The truck has a wide range of tuning adjustments, is extremely lightweight and features all-new suspension and steering geometries. It has been designed to allow for easier maintenance with simplified differential access, high quality hex hardware and no e-clips are used anywhere.
    The Hellfire will sit along side the Savage in the HPI monster truck line-up. The Hellfire is fast, low and aimed at track enthusiasts, while the Savage is a proven “basher” with oversized durability and maximum ground clearance. Both trucks will be available in ready-to-run and kit versions.
    Due for release before the end of the year, stay tuned for more information on the Hellfire.
    Hellfire features:
    • Purpose built high performance monster truck right out of the box. This is not a buggy conversion!
    • Internal drive ratio is optimized for .21 and .28 size race engines.
    • Steering and suspension geometries are designed specifically for this truck to maximize performance.
    • Low center of gravity for increased responsiveness and better chassis balance.
    • The front and rear differentials can be removed by taking out six screws.
    • The removal of four screws allows access to the center differential.
    • No e-clips are used, anywhere!
    • Hex sockets reduce the possibility of a stripped screw.
    • Adjustable front and rear inboard toe with convenient urethane eccentric bushings.
    • Front inboard toe angle adjustments: 0 degrees to -2 degrees.
    • Rear inboard toe angle adjustments: 2 degrees to 4 degrees.
    • Adjustable front and rear camber using strong steel turnbuckles.
    • The camber can be fine tuned to suit your track conditions.
    • Anti-dive adjustments: 0 degrees to 2 degrees in 0.5 degree increments.
    • Anti-squat adjustments: 1.5 degrees to 3.5 degrees in 0.5 degree increments.
    • Front kick-up angle: adjustable from 21 to 25 degrees.
    • 24 possible shock positions available to fine tune your suspension.
    • Spring clips are included to fine tune your ride height.
    • Four different shock pistons are included for a wide range of tuning options.
    • Different compression and rebound can be achieved with tapered shock pistons.
    • Damping can be fine tuned with different diameter holes.
    • Adjustable steering geometry.
    • Adjustable brake bias to control entry steering and jumping.
    • Chassis braces included to adjust overall chassis stiffness for smooth or bumpy tracks.
    • New, high RPM .28 K4.6 HO engine with increased HP and torque.
    • Hard anodized exhaust pipe for maximum power.
    • High flow 2 stage air filter for maximum engine protection and increased engine performance.
    • Continuous radius exhaust header for maximum exhaust flow and power.
    • Wire routing protects wires from moving parts.
    • Fuel tube routing system prevents line breakage and promotes better fuel delivery.
    • Fuel splash guard keeps fuel splashes away from the brake disk and drivetrain.
    • 150cc fuel tank for longer run times than buggy spec 125cc equipped trucks.
    • Internal fuel tank filter and external high quality fuel filter for maximum engine protection.
    • Low center of gravity flush mounted radio box.
    • Secure transponder mounting system.
    • 1100 mah, 5-cell receiver pack with 2 hour wall charger included.
    • New high strength aero dish wheel with 17mm hex for added durability.
    • All driveshafts are CV style joints maximum durability and high efficiency.
    • 3.5mm titanium nitride coated shock shafts for durability and maximum performance.
    • Titanium nitride suspension pins are extremely durable and provide smooth suspension action.
    info taken from : http://www.hpiracing.com/hellfire/
    -= Prowd Owner Of HPI SavageSS 4.6 =-
    Ha! Now I know what to spend my year-end bonus on....
    I can haz diving?
      Available in Kit Version some more ley... woohoo..
        Heheh. Yup. All the more reason to start putting aside $$$.
        I can haz diving?
