Originally posted by nic
Nodding away
Found in the manual.. the nodding effect is cause by depressing the throttle at too slow a rate... mainly during the running in peroid since the throttle is depress over 2-3 second to 0.25/0.5 throttle.
Also.. solved the OS plug misfit accidentally. didn't know know to take that EZstart cable out.. so was pulling with all the strength until the sping go "loosen".. I kinda "unscrew" the spring a little, to make it wider, and now it fit the OS No 8 nicely...
It is definitely a different kind of fun... especially relaxing after the full concentration of heli flying... "just let it go wild" hehehehuh
Hmmm....that's a convenient solution!Originally posted by nicAlso.. solved the OS plug misfit accidentally. didn't know know to take that EZstart cable out.. so was pulling with all the strength until the sping go "loosen".. I kinda "unscrew" the spring a little, to make it wider, and now it fit the OS No 8 nicely...
Simple and effective!
