Is it possible to fit a Tamiya TT01 Spur Gear on the Sparrowhawk car?
TT01 Spur Gear for SparrowHawk?
Thanks Bro.
My car differential gear is also extremely very noisy and it sound like grinding whenever i increase throttle to Full. I stripped the gearbox and the gear are greasy. What is wrong with it?In politics, there are no permanent friends or enemies only permanent interest - Lord Palmerston
Or maybe your differential gear worn out liao?
AIR
HB K2 - Service
CopterX 450 - Hanger
IFO - Service
Walkera H05 mini plane
JR X3810
LAND
Kyosho Javelin - Garage
Tamiya TT01 Subaru WRX - In Service
Tamiya M03 Hello Kitty Swift - For wife
Cen Mini Madness - For son
Team Losi Speed T - In Service
Tamiya TamTech Frog
Sanwa MXA
Sanwa MX3S
Losi 2.4GHz
Crash Lander
Can crash land anytime anywhere
My car differential gear is also extremely very noisy and it sound like grinding whenever i increase throttle to Full. I stripped the gearbox and the gear are greasy. What is wrong with it?"Drifting is not about speed, is about style"
Yokomo Drift Package 1.50x overdrive
Team Magic E4D 1.70x overdrive
Thundertiger Sparrowhawk VX 1.50x overdrive
天天吃阿钙,我有健康的膝盖。
I took out the motor mount and remount the pinion to the spur gear. The sound still remain. The grinding sound is coming from the diff gear box, not from the motor/pinion/spurgear. Is there anything else i can do abt it?
The grinding sound is damn really irritating, tah boleh tahan....In politics, there are no permanent friends or enemies only permanent interest - Lord Palmerston
Originally posted by flameangel View PostI took out the motor mount and remount the pinion to the spur gear. The sound still remain. The grinding sound is coming from the diff gear box, not from the motor/pinion/spurgear. Is there anything else i can do abt it?
AIR
HB K2 - Service
IFO - Service
JR X3810
LAND
Tamiya TamTech Frog
Sanwa MXA
Sanwa MX3S
Losi 2.4GHz
Crash Lander
Pour epoxy flood the diff gear box - straight direct drive (sure no sound) : )
Change all gears in the diff setup include bearings.
Strip all parts in diff and see any loose screws or plastic or debrits or gears teeth dent (clean soak/wash w kerosine). Check carefully to be sure all in smooth running.
Happy CNY stripping : ) will drift one day w you brother in car park
The grinding sound is damn really irritating, tah boleh tahan....For sale
Flamey, to confirm your differential are good, i suggest you lock out both front & back differential with blue tack. if the sound disappear, than it's the differential gear problem. if the sound still there, than it's other stuff. Pinon, spur, bearings. etc. hehee...
AIR
HB K2 - Service
IFO - Service
JR X3810
LAND
Tamiya TamTech Frog
Sanwa MXA
Sanwa MX3S
Losi 2.4GHz
Crash Lander
Originally posted by flameangel View PostI downgraded to Tamiya 21T and applied Tamiya grease on the pinion and gear. Sound so much better now.
Thanks to speeder for tweaking my car. Car is now better than beforeFor sale
