Pb charging advice
    Pb charging advice
    Hi guy, AT wat max amp can i use to charge/ discharge my 12V 7.2 Ah Lead acid batt. i am using bc6.THanks
    Mini Titan
    JGF500th
    CC45
    Hitec 65HB x 3
    Futaba 9257
    Futaba GY401
    Align Trex600N Pro
    JR PCM 9X II
    e-STATION BC6
    kong lipo
    Dualsky
    ace RC
    x TREAM
    I charge my 12V2.3Ah at 0.3A. Use slow charge and they last longer, thats the advice I got from seniors. You can try 10% of the 7.2Ah, which is about 0.7A?
      Hi..
      I sort of lost track on how to charge the PB 12V 7.2Ah..
      Can someone help me out..
      What Amp to set and how long to charge
      I've attached a picture to show..
      Thanks a million..
      quester
      Avant Aurora (E1)
      Avant Aurora (E2)
      Mcp X
      GAUI X5
      LOGO 550SX
      WTS
        Originally posted by remotemadness View Post
        Hi..
        Thanks a million..
        quester
        anyone can provide some light as to how long to charge this battery..
        how do I know when to stop..
        I've never charge this batt before
        Avant Aurora (E1)
        Avant Aurora (E2)
        Mcp X
        GAUI X5
        LOGO 550SX
        WTS
          With computerised hobby charger, charged in Pb mode, 12V 0.7A until the charger stops automatically? Duration depends on battery state of charge. Can take up to 10-16 hours.
            Thks bro..
            But the charging time is set by yourself leh.. That's why I'm not sure how long to charge..
            How do we know when it's full and stop charging..
            Thks
            Q
            Avant Aurora (E1)
            Avant Aurora (E2)
            Mcp X
            GAUI X5
            LOGO 550SX
            WTS
              Thks bro..
              Thks
              Q
              You mean your hobby lipo charger cannot auto cut off? Maybe the charging time is the safety timer. Can try set it to 10hrs. Full should hit around 14.4V, current will reduce, like how lipo is charged. Constant current then constant voltage.
                yes the charger will auto cut off..
                my charger is pre-set to stop after 5 hrs..
                ok.. now that's something that I never think about..
                constant current to constant volts..
                will try and see how.. thanks for the info and help..
                Q
                Avant Aurora (E1)
                Avant Aurora (E2)
                Mcp X
                GAUI X5
                LOGO 550SX
                WTS
                  Q
                  No prob.
                  Pb charging is pretty similar to lipo. Just that fully charge voltage is 14.4V and charge rate is 0.1C. May vary between types of batteries and use, but these are safe values.
