I found this very interesting old thread.
Corrugated plastic has great potential. This is my latest scratch built using 2mm thick CP material. It is only a few days old.
Scratch built SPAD pusher jet built from 2mm thick corrugated plastic.Video shows the agilities of this radio control model plane. No tendencies of tip stal...
This particular design SPAD has great potential.
enjoy & cheers
Hi Babylon5,
I read through the step by step, but can't find any dimension / size of the wing and fuselage. May I know what is the size /dimension? thank you.
sorry, at the moment the fuselage dimension is just simple rough sketches .
I could give you wing dimension but not the fuselage as its difficult to re-produce on PC due to irregulars lines. The vertical fin is approximately 30 to 40 of the L& R wing area.
Attached is the 29.1 inches wingspan wing dimension.
You may need to do some experiment to get it right. Try the flat or profile type fuselage.It is easier to built.
cheers
L=(8.5+1.2) inches
so the balance 35% of L=3.395Inches =3.4inches (rounded off) from the vertex join of the delta wind.
This plane is very stable in flight. No nasty habit.Can fly inverted, slow or fast. Does not stall easily unless you try to land without power and flair the elevon too early.
Note this plane is very similar to the WWII warbird ME163 Komet "tailess delta warbird"
Its 72 cm instead of 80 cm. So everything is downsized.
You can simply upsize everything to 0.9 m or 1 m should you wish to build with 3mm corflute / corplast.
It should be tonnes of fun!
I've attached my sketchup file for ease of sizing.
Nice, here is my un-original mugi. Its a single fin. It has less drag than the twin fin setup.
It flies very fast so much so that at high speed the control become sluggish. I found out that at high speed, the force generated to the surface control is bending and warping the control rod. 2mm hollowed carbon rod added to stiffen the control rod(i hope will fixed the problem) . Spacer was added to both the left wing so that the airfoil came out symmetrical after folding.
You won't find this feature on the original mugi
cheers
Thank you for the dimension. Can't wait to built up soon.
I is waiting for the first guy in SG to build this 8 ft coroplast piper cub.
I think it is possible to built a scale up version of the mugi to 8 ft wingspan but you will need a truck or a lorry to transport the aircraft.
Another thing to comment on the piper is there is no dihedral on the wing so am not sure if the stabiily will be affected. Unlike the delta, the sweptback and delta wing together with the reflex elevator setup provide some degree of stability in flight.
Mugi with many differences. One of its kind. Built with a functional lifting fuselage. Single vertical fin to reduce drag and improve high speed performance....
This Mugi is fast because of the lower drag , since single fin vertical stab is deployed.
More pictures and videos and the build thread of this Mugi can be found in
