help - scavenging an edf motor
Strange... looks like a collet-type prop adaptor.
If that's the case, then the collar is just wedged in tightly by friction. Pull off the collar? That's the only way to loosen the grip of the collet on the motor shaft.------------------------------
will try it out. thanks for the help!
it's probably 2800 kv and optimised for 4s in a 70mm fan"Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
ok, it's out!
6x5 on a 3s should make it nice and fast."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
