Enlarging 7mmSq thru hole to 8mmSq hole.
    I have a question. What is the best way to enlarge a 6mm deep 7mm square hole to 8mm square hole.
    The material is passivated mild steel.
    Keep Moving, Look Forward, No Regrets!!
    Objective is to use a 8mm spindle shaft in an existing 7mm gearbox.
    I want to use the Sherline Vertical Milling. What cutting tool would be best suited?
    I got 200 pcs to do. :toetap05: <br> <br>
      considering shaving off 0.5mm wall per side, there is a good chance to use a custom 8mm x 8mm HSS square form tool to "punch" it thru. The custom tool can be clamped onto a conventional Mill / Drill and like DIE CUT, form through the 7mm square.
        This is good news!!. If you have one in stock ,message me the price of this form tool. Thanks a lot!
          I really love the fly cutter. Its becoming my favorite tool. <br> <br>
            If you cannot make the hole bigger, make the SS shaft smaller!. LOL.
            680 sides to mill down 0.5mm deep/side , 44.2Meters total distance OMG. <br> <br>
              There is always a solution to any engineering problem. Ha. all done and good to go. <br> <br>
