Any one got any idea where could i got one of those from Singapore ???
3 Axis Stepper Motor Controller
i suggest you look for 4 axis, an addition axis for rotation/spare is always good.
not sure about local, but in the net, there are plenty.
try searching for "hobby cnc controller".
to find out if the controller is good, go to cnczone.com forum and search.
with USD weak, may be a good option.
if you want to try your luck on 2nd hand,
there is a shop at simlim tower level 3, think is "kaisin"
their price is a bit on the high side.
good luck
XRB SR Lama
Robotis Bioloid
Robot Bear
Alamak, u nv recommend Sherline 4 Axis controller!!!!!
small cnc machine, dremel rotary tool, proxxon tools, mini metal lathe, desktop cnc machines, small cnc mill, sherline cnc machines, dremel Singapore
It is not the cheapest but definitely is one of the most compact and less heat generated unit.
It save you a lot of connection issue if you are not electronic savvy. No troubleshooting, cover with warranty
Mike
