Selling the following three planes to clear space on a first come first serve basis:
1. P-51D Dago Red 1600mm EPO w/Electric Retracts, Flaps, Lights (PNP) @ S$150
> Wingspan: 1600mm
> Length: 1400mm
> Flying Weight: 2800g
> Motor: 45-58 Brushless
> ESC: 80A w/BEC
> Prop: 16x6 Four Blade
> Servo: 9g x 4, 17g x 2
> Retracts: Electric Servoless Type
> 6 Channel (thottle, aileron, elevator, rudder, retract, flaps).
Together with the plane, it comes with some free items as per the attached photo below:
Following video for reference:
Note that one of the Aileron Servo need to be replaced, which I have provided two free Servos under the free items pack.
2. Hokusei SBach 342 Balsa & EPP SC @ S$150 (New In Box)
This Hokusei SBach 342 is a scale 3D plane made of Balsa Wood frame covered with EPP material. It is lighter than most balsa scale 3D planes of the the same size. It has great flying characteristics: tracking very well like a bigger plane and harriering without wing-rocking.
- Wing Span 1035 mm (40.7 inch)
- Length 990 mm (39.0 inch)
- Wing Area 21.3 sqdm (330.2 sqin)
- Flying Weight 670 g (23.6 oz) with no battery
- Propeller APC SF 11x4.7, APC SF 10x4.7
41” 39”
Together with the plane, it comes with the Motor, ESC and Propeller as per the attached photo below:
Following are the videos for reference:
https://youtu.be/pcXVzQ6mC7M and
3. Dynam C-188 Crop Duster Orange 1500mm (59”) Wingspan EPO (New In Box) PNP @ S$200
- Wing Span 1500 mm (59 inch)
- Length 1005 mm (39.6 inch)
- Servo:9gx4pcs
- Speed Controller:Tomcat Skylord 40 Amp ESC with XT60 connector
- Motor Size:BM3720A-KV650 Brushless Outrunner
- Flying Weight:1300g
Contact me @ 9430 8993 for viewing and collection in Sengkang
> Wingspan: 1600mm
> Length: 1400mm
> ESC: 80A w/BEC
41” 39”
- Servo:9gx4pcs
