Took another route..
Jr XG8 TX (used) MODE 1 (u can easily change to mode 2) $170
1 x RG731BX with RAT01Y Xbuss $105
1 x RA03TL Remote antenna To be used with RG612BX $40
3 X RG612BX Xbuss (nice little rx) $70 each
2 X RA01TL remote antella full range
1 X JR DMSS sensor adaptor TLS1-ADP $30
2 X TLS1-BVM battery voltage monitor $50 each
1 X TLS3-ROT Pulse sensing rotation sensor (RPM) $35
- Wall charger (included with the radio)
- Neck strap (Included with the radio)
- JR Propo TX case (Included with the radio)
- 2 pcs of color carbon sticker $35 each
You cannot find this anymore in the market.I ve got them from a connection which made it for me.
Currently installed the black carbon look. If u dont like u can remove it and apply the one u like.
The radio is working like it should. Zero issues.
Normal wear from usage which has been took care from the skin wraps.
The sensor will give u battery voltage telemetey and rpm readings.
Asking $380 for the whole lot.
PS:I ve insert general picture of the rx coz they are actually installed in my helis. Just FYI.
Chris
92712238
Chris
92712238
