Description:
B6AC Charger is a multi-function charger, it supports dual input, is to use the built-in high-performance microprocessor controlled high-tech and professional software for fast charge / discharger, which supports rechargeable battery types include: Li-ion , Li-Poly, Li-Fe, NiCD, NiMh and Pb, covering almost mainstream rechargeable battery types. It supports up to six strings polymer lithium balance charging, charging currents up to 5A. It also has a discharge function, discharge current up to 1A. This product is also built-in polymer lithium battery balancer, you can string two, three string, 4 string, 5 string, 6-string balance polymer lithium battery charging, so charge better. Side of the fuselage design of the temperature sensor interface. B6AC uses a backlit dot matrix LCD display, can display the operation menu and charging status, convenient and intuitive, but also very beautiful.
This item is for a rapid charger/discharger for all kind of battery of RC hobby, with built in balancer for lipo battery. Battery that can be charged by this charger,Lipo / Li-ion / LiFe / NiMh / NiCad / Pb / Lead Acid
Specification:
Operation voltage range DC 11.0 ~ 18.0 V
AC 100V ~ 240V 50/60Hz Circuit power AC to DC adaptor
(DC 11.0 ~ 18.0V / 5A)
Max. charge power 50W Max. discharge power 5W
Charge current range 0.1~5.0A Discharge current range 0.1~1.0A
Current drain for balancing Li-Po 300mAh/cell NiCd / NiMH battery cell 1~15 cell
Li-Ion / Polymer cell count 1~6 series Pb battery voltage 2V~20V
Weight 749g Dimensions 134 x 142 x 36 mm
Package included:
1x IMAX B6AC Li-Po battery balance charger (Built in Power Supply)
1x AC Power Supply wire
6x T plug wire
1x English manual
sgd50
whatapps 96961229
Specification:
Package included:
6x T plug wire
1x English manual
sgd50
whatapps 96961229
