Trex 500 FBL unable to lift off
    I will like to seek some advise regards to what are possibilities my TREX 500 FBL (Beast X) unable to lift off ground. I had tried the different pitch curves and the throttle curves but still not able to lift off the ground.
    Norm mode:
    My JR TX Pitch curve setting: L: 0, 1: 16.5%, 2: 33%, 3:50% 4 : 66% 5: 85%, H: 100%
    Throttle curve setting: L:0, 1:,30%, 2:45%, 3:60%, 4:72%, 5: 85% H: 100%
    Appreciate all your expertise advise thank you.
    Whats ur blade pitch and headspeed at 100%?
    Too many helis!
      Hi my blade pitch -8 0 +8
        Too low, try 12 deg in both ends. Headspeed above 2800 rpm.
        Too many helis!
          Yes, pitch is too low. But even with -8 0 +8, you should be able to lift off the heli.
          I think the real issue is something else.
          Can you post more details of your setup. Post some videos if possible.
            u can bring ur heli to hoya field on sat morning. Me and another joker will be there between 7 to 9am.
            Too many helis!
              I love you too...a**hole...WAHAHA!!!
              Heli-ADDICTION:
                Yes will do ... Many thanks guys...
                  I Wish too!!! Working...
