OrangeRX LRS URLS High Power telemetry combo
This is a high power 433MHz RC and telemetry combo based on the custom OpenTX URLS Firmware - naturally you can flash OpenLRSng on the modules as well.
This combo allows a high power 2 way 1Watt telemetry serial link together with the normal RC type connection.
What does this mean: Telemetry data is directly transferred via the serial air interface in both directions. You can connect any serial type data stream and transfer it bidirectional via the 1W air interface (e.g. APM Mavlink from Groundstation to UAV)
Set Includes:
1x OrangeRx Open LRS 433MHz TX Module 1Watt (1000mW) JR/Turnigy compatible
- flashed with URLS FW
Module incl. of 3D printed covers with access to the program pins and direct connection of Antenna (90 degree antenna offset build in)
1x OrangeRx Open LRS 433MHz 12Ch Receiver Module 1Watt (1000mW)
- module flashed with URLS which allows 1 Watt 2 way telemetry communication with the respective URLS TX above
This is a hacked Open LRS 1Watt RX module (Futaba type) which comes with PPM connection as well as serial telemetry TX/RX and RSSI connectors compatible with URLS.
Flashing it to OpenLRSng is of course possible but PPM pins would need to be changed internally as URLS and OpenLRSng use a different pinout for the TX->RX conversion.
Price for the set: 60 S$
Set Includes:
