Any one flying the above mention multi rotor ?
Align M480L / M690 Flyer..
Originally posted by ah_liang View PostI have a 480.Heli-ADDICTION:
Glade to know that I ain't the only one flying it.. let's share and learn from each other here.. BTW any one using a spectrum dx on it?YOu FLy, You CRASH, YOU LEARN..
Mini Titan
JGF500th
CC45
Hitec 65HB x 3
Futaba 9257
Futaba GY401
[U]colco lama v5[COLOR=Red]][COLOR=SandyBrown]
Align Trex600N Pro
JR PCM 9X II
e-STATION BC6
kong lipo
Dualsky
ace RC
x TREAM
Originally posted by boo_saa View PostBro how you bind the 480 in failsafe.. me too have the same set up
If you are using Spektrum Tx, try the following steps.
1. After you have assigned all the switches and the direction of all channels are set correctly. Connect the APS-M to the PC and run the setup program.
2. Power up the multicopter, and see that the APS-M is connected to the software.
3. Activate the "Home" switch (i.e. turn on Home switch), you should see that the software indicates the switch is in the "ON" region.
4. Increase (or decrease) the travel of the Home switch (at ON position) until you see the software indicates that the switch is in the "FS" region.
5. Turn off everything, and proceed to re-bind the TX and Rx. During the binding process, make sure the Home switch is in the "On" position before you turn on the Tx for binding.
6. After the binding process, adjust the travel of the Home switch "On" position back its normal value.
7. To verify if failsafe is working, connect the APS-M and run the PC software. Turn off the Tx to see if the software indicates Home switch is in FS region.
Originally posted by nb8686 View PostIf you are using Futaba Tx, it is very easy, just follow the instructions in the manual.
7. To verify if failsafe is working, connect the APS-M and run the PC software. Turn off the Tx to see if the software indicates Home switch is in FS region.YOu FLy, You CRASH, YOU LEARN..
Mini Titan
JGF500th
CC45
Hitec 65HB x 3
Futaba 9257
Futaba GY401
Align Trex600N Pro
JR PCM 9X II
e-STATION BC6
kong lipo
Dualsky
ace RC
x TREAM
