Align M480L/M690L Multicopter
    Originally posted by nb8686 View Post
    The one you suggested will not work:
    You need something like this:
    You need a controller that is able to reverse the 12V polarity applied to the retracts when the assigned tx switch is flipped.
    Thanks. I will try it tonight. Then see where to buy such controller.
      I just tried the +/- direct into a 3S lipo pack and it works! Reverse the polarity and it retracts. Thank you very much for the insight.
      Now to go buy the controller.
        The local hobby shop(Zenm Tech) that I got my M480L from replaced my cracked LED clear cover with no question asked. One to one exchange with a brand new part. However the wording on the part is the other side but it doesnt matter.
        During removal and installation of the cover, I realised the esc came with dip switches. So I think you can select the colour of the LED you prefer.
Name:	M480L Defect 004.jpg
Name:	M480L Defect 005.jpg
Name:	M480L Defect 006.jpg
          Got it up and flying again. Flies well. Still working on the retracts, akan datang.
            Got the retracts controller and connect it up. It works. I liked that it has a fail safe feature built-in. On loss of signal, the retracts auto lower the landing gear. Also fixed up my 3 Axis iFlight gimbal to the M480L. All flies well but flight time on my 6S 5000mah pack is now only 4mins. And the low voltage alarm came on. Need batteries.
              Thats a heavy setup, I only had a gopro on mine.
              Too many helis!
                Thatz the purpose of me getting the M480L. Its a stylish heavy weight quad.
