Align M480L/M690L Multicopter
    Originally posted by ZenmTech View Post
    How about this Sunday morning at OHR?
    Sorry boss.. where is OHR
    YOu FLy, You CRASH, YOU LEARN..
    Mini Titan
    JGF500th
    CC45
    Hitec 65HB x 3
    Futaba 9257
    Futaba GY401
    [U]colco lama v5[COLOR=Red]][COLOR=SandyBrown]
    Align Trex600N Pro
    JR PCM 9X II
    e-STATION BC6
    kong lipo
    Dualsky
    ace RC
    x TREAM
      OHR: Old Holland Road.
      See map below:
      Zolta Batteries Distributor
        See map below:
        [ATTACH=CONFIG]136210[/ATTACH]
        irritating message. i type faster than 50 secs lah!!!!
        sorry missed the message.
          M690L with GH4
          Another video (M690L with GH4 and G3-GH Gimbal).
          Part1.
            Part 2.
              Part 3.
                See map below:
                This is a really good simple map of OHR! ;)
                  I was looking for a heavy lift multicopter with aesthetic pleasing look. And I found it!!! Its the Align M480L. Its huge and lots of space + options. I was glad that it now comes in kit form as I prefer to use my favourite brand flight controller.
                  After watching the Align build video a few times, I started my build. I completed my build and ready to fly in 3.5hrs, including soldering bullet connectors for the FC and XT60 to XT150 adapter for the 6S batteries. Also being familiar with my favourite brand flight controller, set up was a breeze.
                  After maiden flight photo. Flight was as expected, stable. However, I set the low voltage alarm too high so have a rather short flight time of 2mins. Have corrected that.
                    However there was a defect on one of the rotor arms. The clear plastic has cracked on the inside. Will need to claim warranty for a new clear plastic. Lucky I bought my M480L locally. But this does not affect the performance of the quad at all.
Name:	M480L Defect 001.jpg
Name:	M480L Defect 002.jpg
Name:	M480L Defect 003.jpg
                      As I am not using Align's flight controller, I was not able to get the retracts to work. The retracts require 12V. So I split the signal wire and plug the red and brown to the ALign PCU for the power supply and signal wire to my rx. It does not work at all. I tried using the servo tester with the signal wire. It still does not work.
                      Anyone got any idea how to make the retracts work?
Name:	M480L Retract 001.jpg
Name:	M480L Retract 002.jpg
Name:	M480L Retract 003.jpg
                        Only two pins are used (i.e. the ground and + pins). Apply 8.4V to 12V to it. Reversed polarity will make the retract move the other way round.
                        Normal Position
                        Ground Pin (black wire) -> Connect to 0V
                        + Pin (centre pin, red wire) -> Connect to +12V
                        Retract Position
                        Ground Pin (black wire) -> Connect to +12V
                        + Pin (centre pin, red wire) -> Connect to 0V
                          How do I do this remotely while flying?
                            You need a RC remote control board for retract (or landing gear controller) to do that. Need to set aside a tx/rx channel for this function.
                              Something like this? : http://www.hobbyking.cm/hobbyking/st...ff_Switch.html
                              But this one cannot handle 12v.
                                Something like this? : http://www.hobbyking.com/hobbykin/st...ff_Switch.html
                                The one you suggested will not work:
                                You need something like this:
                                You need a controller that is able to reverse the 12V polarity applied to the retracts when the assigned tx switch is flipped.
