Normally Zenmuse tilted 45 deg means no signal from radio or X1 is not calibrated. Or the end points on gimbal travel not set properly.
- Calibrate your TX with RC assistant (not phantom assistant)
- Go to Phantom assistant and calibrate X1
- In P2 Assistantgo advance > Gimbal adjust limits its still not getting full tilt movement
If this is not issue maybe do a quick video to show the issue here and others might be able to help.
