MHZ Mystic 114 "Budlight"
    Got it from Mel279, hull and hardware only. Setting it up now with my own electronics.
Name:	MHZ Mystic 001.jpg
Name:	MHZ Mystic 002.jpg
Name:	MHZ Mystic 003.jpg
Name:	MHZ Mystic 004.jpg
Name:	MHZ Mystic 005.jpg
    New props just arrived, need sharpening n balancing.
    Nice boat!!!
    What will you be using to measure the speed of the boat?
      Originally posted by mave View Post
      Nice boat!!!
      It will be my trusty Garmin Forerunner 101 :
        Cool! Will try to get myself one!
          In all seriousness, do not get this one. Get the latest Garmin Forerunners or etrex that are using the latest gps chipset. This one uses the old gps chip set, whenever u turn it on, u have to leave the unit on the spot for 5-10mins before it could search n locked on the satellites. Newer models lock on within secs.
            Oh?! Thanks for the info. Else I end up wasting money. Thank you!
              Tried to maiden her last Sat. But one of the ESC failed. Motor was cogging and not turning. Boat going in circle, had to limp her back to shore.
Name:	MHZ Mystic 006.jpg
Name:	MHZ Mystic 007.jpg
Name:	MHZ Mystic 008.jpg
                At home, while trying to re-lube the cable, saw one of the cable partially broke. Not even running properly and the cable broke.
Name:	MHZ Mystic 009.jpg
Name:	MHZ Mystic 010.jpg
                  Received my 3/16 flex cable and went ahead to change the flex cable.
Name:	MHZ Mystic 011.jpg
Name:	MHZ Mystic 012.jpg
Name:	MHZ Mystic 013.jpg
Name:	MHZ Mystic 014.jpg
                    Received my repaired esc last week and managed to re-maiden this morning. Conditions were perfect, calm waters and little wind. Unable to full throttle, risk getting a blowover. Need more tuning to get the setup right. Unable to get a GPS lock on my garmin so unable to determine her speed. But she felt the fastest boat I have driven.
                    Video of her last run this morning :
                      [SIGPIC][SIZE="4"][FONT="Arial Black"][COLOR="Red"]DagoRed Rs131MPH[/COLOR][/FONT][/SIZE][/SIGPIC]
                        Did another run last Sat and managed to get a lock on my Garmin GPS. As expected, it was the fastest boat I ever driven, it clocked a max speed of 69.9mph or 112km/h.
                        Here is a video of my run :
Name:	MHZ Mystic 016.jpg
Name:	MHZ Mystic 015.jpg
                          Wow good run!!!
                          By the way, how do you secure the gps on the outside? Double side tape?
                            Hi Adrianli, finally met u on Sat....
                            The 6S on the Genesis is too powerful, full throttle and the boat flipped....
                              Wow good run!!!
                              I used blu-tack and three layers of packing tape. The inside of the hull is CF, Garmin unable to get a signal when placed inside the boat. So have to put it outside. The good thing abt Garmin Forerunner, it is water resistant so no problem putting it outside.
