Removing a rounded screwhead
Originally posted by Wind_Chaser View PostCan try this.. https://www.buyspeedout.com/iispout/...b-7b6348b3b8e6Too many helis!
Originally posted by ah_liang View PostAvailable locally?
I bought a set a long time ago.
Well, not exactly the same type but works the same.
It is basically a left hand screw.
First you drill a hole, put the exractor bit in, and just screw out the broken bolt/screw.
One very important thing to note is that the smallest bit may be too large to extract a servo screw.
Maybe mine was a S$6/- cheapo.
Then again, those stylo mylo ones may also not be small enough to handle small screws... expensive only.
Any apek hardware shop should have the type I have in stock.
