Power supply for Graupner Duo 50
    Wanted to ask if its necessary to get the external power supply if I'm daisy chain charge lipos for the Duo 50.
    Ken
    Ken
    With AC mains it's going to output a total max across both channels of 120W. Each channel is capped at 10A output.
    With the external DC power supply you now have 180W per channel or 250W if using only 1 channel. Still the same 10A cap per channel.
    Here's the question to ask yourself - will you be hitting the 10A cap or max power wattage limit first? What capacity and number of cells are you trying to charge?
      Sorry, haven't checked in recently.
      I'm charging 6S 4500mha cells and wanted to do all 6 at the same time. Will probably get the multi balancer from Revo to allow that
