Air Compressor repair
    Does anyone has a place to recommend for Air-compressor repair..
    I think mine was sitting there for too long.. It's like something in there got stuck and cannot start.. It has a humming noise.. but just won't pump..
    quester
    Avant Aurora (E1)
    Avant Aurora (E2)
    Mcp X
    GAUI X5
    LOGO 550SX
    WTS
    this is how it looks like..
    It seems the black little square thing that's suppose to trigger the power to off when full is not working..
    quest
    Avant Aurora (E1)
    Avant Aurora (E2)
    Mcp X
    GAUI X5
    LOGO 550SX
    WTS
      If too long didn't run, pistons of compressor may get jammed. Hence humming sound and not running. Good that you stopped if not motor coil may be burnt. See if any way you can access to turn the motor. Then start again.
      The Black box you referring to is pressure cut in and cut out when pressure reached it's high setting(stop) and low setting (start).
        Hi ben,
        Thanks,
        It's the pressure thing that's not holding up.. It keep leaking.. and it's making the compressor work all the time.. Until it's kappot now..
        any where you know that does repair..
        There use to be one around rotors.. but it's gone now..
        quest
        Avant Aurora (E1)
        Avant Aurora (E2)
        Mcp X
        GAUI X5
        LOGO 550SX
        WTS
          There is a hardware shop along Sims Ave between Lor 11 & Lor 13. Seen contractors bringing along their electrical tools to repair. Another place is along Jurong Kerchil opposite Toh Yi Estate. Also a Hardware shop. You can see many compressor outside. Rgds
            thks for the information..
            A bit too far for me.. But if there's no alternative to some where near town.. Then I have got no choice but to visit one of those..
            thanks
            quest
            Avant Aurora (E1)
            Avant Aurora (E2)
            Mcp X
            GAUI X5
            LOGO 550SX
            WTS
              Looks like you need replacement for the auto-cut device and the rubber o-ring or sealant also needs replacement. I have sent my compressor to fill compressor oil at a hardware store in Sungei Rd. Shop is somewhere in the middle next to a shop selling Makita power tools. Check it out.
                Hi Jerry,
                Thanks for the headsup
                Is it behind the "ah boy" motor bike place.. kalantan lane
                Sungei is a big area.. With now so much road diversion.. I hope they are still there..
                Avant Aurora (E1)
                Avant Aurora (E2)
                Mcp X
                GAUI X5
                LOGO 550SX
                WTS
                  Air compressor repair
                  Its Kelantan Rd. Shop is below multi-storey car park. Shop is on third shop counting from the right.
                    Thks.. I know where it is now..
                    Hope they do repair..
                    Avant Aurora (E1)
                    Avant Aurora (E2)
                    Mcp X
                    GAUI X5
                    LOGO 550SX
                    WTS
                      I've walk the whole kalantan rd..
                      No one does repair..
                      anyone else has any more suggestion..
                      thanks
                      desperate quest
                      I went down to sunshine plaza to check out new compressor with tank.. It ranges from $380-$420..
                      Avant Aurora (E1)
                      Avant Aurora (E2)
                      Mcp X
                      GAUI X5
                      LOGO 550SX
                      WTS
                        Actually if u are handy man you can change the device and parts yourself. Cheaper this way. Let me check with a friend and get back to you.
                          Compressor shop at ground floor Jln Besar Plaza, Kitchener Rd. Check Google street view. Thats the right place. Friend sent his compressor for repair there.
                            Thks Jerry,
                            I know where.. Coincidentally I'm going there this sat to eat Thai steamboat..
                            Quest
                            Avant Aurora (E1)
                            Avant Aurora (E2)
                            Mcp X
                            GAUI X5
                            LOGO 550SX
                            WTS
                              Found
                              Hi jerry,
                              Thanks for your help.. found them..
                              This is where it is.. They are on the Maude road side..
                              here's the picture of who they are...
                              for those of you that's looking for a repair shop.. This is it..
                              They sells sil-air compressor as well
                              Avant Aurora (E1)
                              Avant Aurora (E2)
                              Mcp X
                              GAUI X5
                              LOGO 550SX
                              WTS
