HP DPS-600PB 12V/24V 47A 1150W Power Supply Build Thread
    Yes, connecting 4&5 to ground will turn on the power supply.
    On your second point, please be aware I only use 1 unit, not a pair.
    Having a single switch for both units would be possible, but I'm not sure how you need to wire it.
      Thanks yhchoong for the great tutorial. 3 years later I'm finally getting around to my mod and have run into an issue. My first supply works perfectly but the second (floating gnd) won't turn on, only the fan turns on. I've grounded 1-5 on the ribbon cable, so I'm not sure what it could be. Any thoughts?
        My way
          Originally posted by rxtxua View Post
          My way
          may I know whats the purpose of your circuit board and what is the advantage?
            Hi. I bought to of these sources, but one of the stop working, and the other also is no turning on ! Anyone have the schematics of this sources ? I am trying to fix then!
