New Products in ApacHobby
    swee ... Maxa
    Share the joy of flying . . .
      Originally posted by rt9 View Post
      you mean the Maxa? :p
      Yup the maxa😍
      But the price is 😣😢😞
        Fit and finish is one of the best we have seen. Lots of carboline everywhere, Unique Bi- and Multi-axial Spread Tow Carbon fabric for Ultralight Structures created by Vladimir.
Name:	new spread tow.jpg
        Asia Pacific Hobby Pte Ltd
        [URL="http://www.apachobby.com"]http://www.apachobby.com[/URL]
        Enquiry Email:
        [EMAIL="info@apachobby.com"]info@apachobby.com[/EMAIL]
          External Bearing kit - Best Upgrade
          Got this from Pang and start fixing it on my Schwing88. Before that I got slop of 1.5mm to 2mm...now it is almost gone may be less then < 0.5mm if I am picky. Worth every single cents and very easy to fix.....you can feel the difference as I compare one wing fix and another not fix..very diffferent.
          Very happy with this upgrade....need it on all your glider.
          Update : Completed all wing servos ....now I wish they have similar for the Elevator and Rudder...
          Jonathan
            Need for speed? Swist F5D from Russia.
            Enquiry Email:
              More ELfs and Blasters in stock for the DLG/Thermal Season. Get them quick before they are gone again!
              We also have Maxa 4E, Sprite, Mni-Gs in. Contact us for colours.
              Enquiry Email:
Name:	Summer Sales - Apachobby main page.jpg
                To Thank our supporters, this is the sales you have been waiting for.
                Be sure to check on some of our high end plane deals and Heli HV servos bundles.
                Enquiry Email:
                  Altis V4
                  Altis V4 Height Recorder and Flight Logger in stock
                  The AerobTec Altis v4 is a barometric altimeter designed especially to record altitude of flying R/C aircraft with additional competition functionality, integrated OLED display and additional telemetry functionality. You can use it as a logger , limiter for F5J, ALES format rules, as an altitude logger for flight recording and later analysis on a PC. It can also be used as telemetry sensor that works with Jeti and Multiplex 2.4GHz receivers and its small enough to be use for as DLG launch height recorder and display.
                  Specifications:
                  Memory: 3.9MB (approx. 15 hour record with 0.1s sampling)
                  Sample time: 0.1 – 25.5s (user selectable with step 0.1s)
                  Dimensions: 20 x 33 x 6.5mm, cable length approx. 10cm
                  Weight: 8g with JR cable
                  Power supply range: 4 – 12.6V
                  Logging:
                  - altitude
                  - voltage
                  - temperature
                  - throttle
                  Compatible with existing all competition rules (FAI F5J, ALES, etc.)
                  OLED display (configurable screen)
                  Telemetry support for Jeti model® and Multiplex® M-Link
                  Upgradeable firmware
                  Integrated USB
                  AerobTec Altis Flight manager software for Windows
                  Enquiry Email:
                    Snipe
                    Snipe arrived.
                    F3K World Champion Joe Wurts, using his experience as an competitor and aerodynamicist, designed his ideal DLG - the Snipe. The Snipe features both new technology and a design driven by his years of experience in DLG competitions. The design incorporates a high-aspect wing and new airfoils to yield superior launches and long legs to chase those far away thermals.
                    Blasters, Elfs, Maxa, Mini Gs restocked.
                    Enquiry Email:
                      Power of Maxa
                      When winds speed is low, that only my DLG get decent time...and also not favorable direction.
                      Don't worry...there is the Power of Maxa 4M on slope.
                      Jonathan
                        Special Clearance sale
                        Savox SC-1267SG Super Speed Steel Gear Digital Servo (HV) now at 50% off.
                        Great for Helis, Planes, Cars.
                        Savox SH-0255MG Micro Metal Gear Digital Servo now at 50% off
                        Enquiry Email:
                          Snipers watch your front, OTOT carry on
                          Snipes in stock, limited pcs!
                          Enquiry Email:
                            FrSky Taranis
                            FrSky 2.4GHz ACCST TARANIS X9D Digital Telemetry Radio System in stock! Yes locally, no more waiting from HK.
                            Receivers and Telemetry sensors also in stock.
                            Enquiry Email:
                              The Moment with MKS Photos/Videos Giveway
                              Do you use MKS servos?!
                              Take a photo or video right now, super prize may be yours!!
                              Enquiry Email:
                                Maxa 4 Pro
                                New for 2014 Maxa 4 Pro. Contact us for more details.
                                Vladimir models together with Joe Wurts, have developed an optimal aerodynamics new tail for Maxa Pro. There have been several custom made pilot models for proof of concept in flight tests. In early December 2013, 3D model of fin and stabilizer was completed. For next 2 months 29 parts of matrices and 8 devices for the processing and assembly was manufactured.
                                Targets for Maxa optimize was:
                                - Reducing tail drag,
                                - Increasing the controllability of elevators and rudder,
                                - Increase rigid of tail and control system,
                                - Reduction in the weight of the tail,
                                - Removable for transport fin.
                                To meet these ambitious goals , we made a new elliptical shape tail boom. Stiffness of the beam is increased by more than 2 times and the weight is increasing just of 9% only. The tail boom is narrowed at the end to the thickness of the rudder for reduce aerodynamic drag.
                                Construction of the fin and stabilizer is construction of Rohacell solid core covering of new ultralight Carboline 26 g / m ². Carboline walls are integrated to the core. Carbon spars laid in the slots of the core. Carbon spars rowing is pre- stretched and pre- uniformly impregnated into the treater http://f3j.in.ua/en/spread-tow-carbon.html
                                Enquiry Email:
