Powering a Snap P1 Offshore Powerboat
    Hi Adrianli,
    Ok 8 helicos, watch this, it's for you.
    video, sharing, camera phone, video phone, free, upload
    I'm helping my friend to fix his new helico, honestly, i prefer offshore, it's easier.
    JET
      Originally posted by JET 99 View Post
      Hi Adrianli,
      JET
      Nice scale helis but do ask your friend to upgrade his heli's rotor heads to flybarless ones for the scale look.
      Will try to remove the motor and swap the coupler by this or next weekend.
        Hi Adrianli,
        This guy is not my friend, we met him once few months ago. he was fixing big scale brushless helicos.
        As soon as you have settled the coupler problem, you try to make a video.
        JET
          Last long weekend, managed to make time to remove the defective coupler. The alu coupler doesnt look good for this setup.
Name:	P1 Snap 025.JPG
Name:	P1 Snap 026.JPG
Name:	P1 Snap 027.JPG
            Installed the older coupler using setscrew to lock the flex cable n motor shaft.
Name:	P1 Snap 028.JPG
Name:	P1 Snap 029.JPG
              Went for her maiden run this morning.
Name:	P1 Snap 030.JPG
Name:	P1 Snap 031.JPG
Name:	P1 Snap 032.JPG
Name:	P1 Snap 033.JPG
                Video of her maiden run. CG was out, need to shift batts towards the rear. Prop was cavitating n on turns, prop was exposed due to her shallow draft.
                Powered by Neu 2230 1Y motor12S2P 10,000mah lipoProp cut down to 58mm dia.Top speed recorded on Garmin GPS was 48mph
                  Check out the recordings on one set of the 12S lipo by Eagletree :
Name:	P1 Snap 12S Lipo X458 001.jpg
                    Top speed was recorded at 48mph. I have not squeezed the throttle fully yet and these are very old set of batts.
Name:	P1 Snap 034.JPG
Name:	P1 Snap 035.JPG
Name:	P1 Snap 036.JPG
Name:	P1 Snap 037.JPG
                      Good evening Adrianli,
                      I hope you're ok, 48m/h for the first run it's good. with new lipos, different props, you 'll achieve 60 m/h or more
                      take care
                      JET
                        Morning,
                        In fact its going to be evening here.
                        I am using this :
                        [ATTACH=CONFIG]116326[/ATTACH]
                        From here : http://www.fastelectrics.com/hardware.asp
                        but no matter how much I tighten, it just doesnt grip the flex cable. Probably too much torque for it to handle.
                        Hi! I got a bottle of the Loctite 648 Retaining Compound. Used a few drops to secure the prop shaft to the drive cable for the HPR. You are most welcome to have some.
                        2013 RC4WD International Team Driver
                          It is not the problem between the prop shaft and drive cable. Its the coupler problem. Has been resolved, changed to my older coupler. It just ran last weekend.
                          Will run it again this coming weekend. Only have one set of old batts for one run.
                            Nice Video, Sweet Maiden! Glad that the couple issues been resolved. Your using 12S for this? What time on Saturday or is it on Sunday?
                              Yup, I run on 12S. I am usually play my boats there ard 7.30am to ard 9am or earlier on Saturday.
                                bro..use the mbp coupler, high quality and well balanced
                                My fleets
                                Stiletto tunnel, DF Mono, EPV 135, CT06 Hydroplane
