DIY foam cutter (hot wire cutter)
    Originally posted by shoyn View Post
    Hi, where did you get the foam? How do you cut out the wing so nicely? Whenever I cut the foam, the angle is always way off.
    You toto ARTFRIEND there has many type of foam
    没办法了,须改变自己,来试应环境。
      They sell the foam that Joe Yap uses?
        Art friends sells blue/pink extruded polystrene foams and white styrofoam.
        What I use on the current projects are high density white styrofoam which is bulk ordered from a factory at Tuas. I can spare a few 1.2m x 1.2m x 50mm think sheets if you need.
