Where to buy?
    Where to buy?
    Hi, may i know where can i purchase depron foam? Using it to make plane. Thanks
    RC IS A POISON!
    I believe it is also called Compressed Foam.
    You can find it from Artfriend, Stationary shops, and local hobby shops.
    Hope this helps.
      hi jimmy, were you able to find it? where do you recommend? im also looking to get some for diy project. hope you can advice thanks!
      "To invent an airplane is nothing. To build one is something. But to fly is everything."- Otto Lilienthal
      "To fly a plane, a pilot must have cool brains and hot hands!"- Dennis John De Witt
      Fubata 7C 2.4 + T6XAs
      E-starter (GWS) - On "Fire", Trainer, -Sold
      SPITFIRE (GWS) - On "Fire", -Sold
      T-45 Goshhawk 64 mm EDF - Lift-off!
      UAV Scratch Build Ver1.1 - It flies! -Sold
      Mini Cessna scratch build - fun!
      F330 Quadcopter W/KK2 V1.5 - Finally Tuned!
      Charger- Turnigy AC6
        Where to buy?
        Guys,
        You can get your foam at JetHobby. If you can't see the link attached, just go to Building Equipment & Materials -> Foam. Have fun!
          I did not find it, but which is depron foam? Compressed foam or epp? Confused over it...
          RC IS A POISON!
            how to identify depron
            i ever bought a pc of depron sheet from Jet hobby b4, if you look at the depron sheet on the left, its a smooth consistent texture while if u look at the EPP on the right, it look more like your regular styrofoam with texture of foam cells interlocking each other..
              so which is actually better and easier to fix? im guessing epp...lol'
              RC IS A POISON!
