Test hover MT with 4 bladed head with BeastX or Microbeast in living room today.
This hover is to test:
1. The feel and behavior of Microbeast on multibladed head. Recently bought Microbeast and this is the 1st time hovering it with this device.
2. Finding the preference RPM required.
3. Testing the Hitec HS-A5076 for tail control.
Result:
So far so good. Microbeast can handle multibladed and to my flying characteristics..but I only test hover in living room so not sure how it perform in forward flight.
Due to Microbeast P.C. software haven't release yet, that mean there is no way to implement phase offset. Therefore, to use it in this heli and to have close to straight linkages on the rotor head, I need to do phase offset by switching around the channel going to the cyclic servo.
In eCCPM120 degree, in MT configuration, the swash plate connection to cycli servos are arrange in 2oclock, 6oclock and 10oclock position. So, I connect Ch1 of Microbeast to right/2oclock servo, Ch2 to center/6oclock servo and Ch3 to left/10oclock. Instead. But by doing so, I need to reverse the direction of the right servo instead. To do this, I program the Hitec HS5065 servo directly using Hitec HPP21. In MB point of view, it is like normal servo but it rotate CCW direction instead. That is the good thing I prefer Hitec digital servo over normal "unbranded" digital servo.
This hover test also verify that HS-A5076 actually can be use for tail servo. The tail hold pretty good.
One thing I a concern is that, the Scorpion HKS2221-1630KV motor is hot. It may not able to handle the load well..especially when include with fuselage. Thus, i might need to replace the motor also.
SH
Result:
SH
