450 heli and stuff
assorted tail blades - gd flying condition
-used?? trex 450 plastic tail blades, yellow - $1
Align white carbon blades 325mm
-only flown 1 flight, as gd as new!
-one of the best carbon blades for the 450!, autos great!
-balanced, plug and play!!
going for $35 only!
NIB trex 450 Landing Skid Nut
-$3
500 stuff
Z Weave 425mm carbon blades for the trex 500 and other 500 helis
-10mm root, no need for spacers
-z-weave, much stiffer than normal carbon blades
-Length: 425mm
-Width: 39mm
-Thickness: 5.5mm
-Weight: 58g each
going for $48
Assorted FG 430mm main blades
-1 side white(with single black stripe) FG like new - $7
NEW, unused trex 500 plastic tail blades, yellow - $5
stock trex 500 align pinions
-barely used 13t - $3
Sim and Stuff
New and unused JR to Futaba square/micro trainer adapter
-used mostly for sim cables to covert from normal JR type to futaba plug
going for $5
New and unused JR to Futaba smaller round 5-pin adapter
-used mostly for sim cables to covert from normal JR type to the smaller round 5-pin futaba plug
going for $5
New and unused JR to older Futaba bigger round 6-pin /Hitech adapter
-used mostly for sim cables to covert from normal JR type to the larger round 6-pin futaba/hitech plug
going for $5
Charger/Balancer/Batts/UBEC/Connector/Power Supply
prolux 1-3 Cell Lithium Polymer green charger
-Quick Specs-
Microchip operational analysis can control the Off point precisely & efficiently.
Using Voltage booster it can charge upto a 3 cell lithium pack (12.6v)
Selectable 1-2-3 cell & wrong select warning.
LED Light & beeper to indicate charging status.
5 Position charge rate : 250ma, 500ma, 1000ma, 1500ma & 2000ma.
Start/Stop Push Button.
Output & input has short circuit protection circuitry
Loud beeper
going for $30 only
Thunder Power Extreme v2 3s 2200mAh 11.1V with Serial no.
-last piece of my tp extreme v2 3s with serial no.
-balancing connector has been converted to JST-XH or align type
-25C continuous, 50C burst
-still as gd as new due to low temp storage and balance charged every time
abt 20 cycles only going for $45 only!!!!
Gyro/Servos
1 x nib + 1 x lightly used inolab/hotgear hgd250hb digital mini servos HS 81/82/85 sized
Product Information
Powerful digital servo with double ball-bearing and precise netural.
It's the first in same range servos to use double ball bearings for precise output shaft.
Specifications:
• Power : 4.8V ~ 6.0V
• Speed : 0.16s/60°,0.12s/60°
• Torque
4.8V--3.0kg.cm(41.67oz.in)(Dynamic torque: 2.5kg.cm(34.72oz.in))
6.0V--4.0kg.cm(55.56oz.in)(Dynamic torque: 3.0kg.cm(41.67oz.in))
• Size : 30.0X13.0X38.1 (1.18X0.51X1.24in)
• Weight : 18.12g(0.64oz)
It is about the same size as a hs82, very light servos for the specs.
1 pc is new, 1 is slightly used <15 flights
great for planes, (500 sized etc)helis,cars, boats etc!
these are more precise(digital), smoother, better centering etc than hs65, hs81, 82 etc
-good quality digital, korean-made servos with local support
-These are DIGITAL servos!
going for $64 for both!!!!!!!!!!!!!!!
hitech hs65hb servo x 1
-gd condition, just changed gears and checked with servo tester
-gd as a spare etc
going for $13
collection is at/near Pioneer Mrt Stn, other arrangements can be made at my convenience.
Items can also be posted via normal post but postage borne by the buyer and I am not liable for lost packages(which is quite unlikely)
Local courier(door to door anywhere in SG) can also be arranged for $6 on top of item total
PLEASE PM me for correspondence.
going for $35 only!
-$3
500 stuff
-Length: 425mm
-Width: 39mm
-Thickness: 5.5mm
-Weight: 58g each
going for $48
Sim and Stuff
going for $5
going for $5
going for $5
-Quick Specs-
Loud beeper
going for $30 only
Gyro/Servos
Product Information
Specifications:
• Torque
-gd as a spare etc
going for $13
